Help needed please guys?
Man of Honour
8 Nov 2007
Outer Space
I've got an EK reservoir, the tube is made of proper glass not plastic, and I've just drained my system that had Mayhems Nano Pastel White fluid but even after cleaning it there is a white cloudy substance inside the glass.
Is there a way to remove this so it's back to its lovely clear glass again?
Some distilled vinegar should shift it. If not there is always Cillit Bang. You may laugh but I have used Lime and Grime on the metal parts of my blocks for ages and it brings them up lovely. Check that it can be used on glass first though.
I had a similar issue with Mayhems pastel green. I took the glass out of my heatkiller res and just washed it with a sponge and fairy liquid came up like new! I did use a blitz kit part 2 after reassembling my loop.
