Hi Guys,
I have a machine to fix for a family member, What it does is freeze after 5-10 minutes of use. The mouse can still function but the keyboard and windows is locked, Now, what i thought it could be is the ram (which i replaced , as i had spares) and it seems to have not fixed the problem. Re-Installed windows on a second hard disk , Stress test with orthos for half hour / hour without crashing. Seems when i go in the start menu , Internet stuff like that it crashes.... Strange?/???
System specs:
Intel Pentium D Dual Core 3GHZ
1GB DDR 400 Ram
Foxconn Motherboard
CPU temps, Idle 26 Degress , Load is 40 Degrees
Any Ideas guys?
Thanks for any help you give!
Jason04R
System specs:
1GB DDR 400 Ram
Foxconn Motherboard
Any Ideas guys?
Jason04R
