- 8 Oct 2014
- Here somewhere!!!
Hi all, I placed a post in the graphic card sectionfor some upgrade advice, and as I had said there I will be upgrading gpu at some point, but I have been given another asus gtx 460 and I want to sli them for now.
Anyway, I have spent most of the day trying to sli and have just found-out that my mb only supports crossfire
after some searching on forums you need this Hypersli software to make sli work on a non sli mb.
Dose anyone know if this is 1:safe 2:works, and where I can download the sofware safely?
after some searching on forums you need this Hypersli software to make sli work on a non sli mb.Dose anyone know if this is 1:safe 2:works, and where I can download the sofware safely?
