help needed quick! 280 oc
Permabanned
4 Sep 2007
Newcastle upon tyne
just baught a bfg oc 280 gtx , i have a crosair hx620 i plugged in the 6pin connector and then went to plug in the 8pin connector but it doesnt fit?!?!. i got an adaptor supplied with the card but it looks like it takes 2x 6 pin connectors to plug in to it. can any 1 help please!!
i have the same psu and it should have 2 modular pcie cables in the box, they are both 6+2 pin like this one
if the connections on your card are like this then use one 6pin & just leave the extra 2 hanging, and on the other one use the six & the extra 2, it should fit no problem :confused:
