Help needed quickly Please
31 Dec 2003
Midlands
Hi guys,
I am going to order a new PC but I dont know too much about the Athlon's.
Could you tell me which system is best from the pre-built overclockers range.
either
"Verso" AMD Athlon 64 X2 4400 Dual Core 'San Diego' 2.2GHz DDR System - Black (FS-012-OK)
AMD Athlon 64 X2 4400 'San Diego' 2.2GHz Dual Core CPU
- NVIDIA nForce4 "PCI-Express" (Socket 939) Dual DDR400 Motherboard
- GeForce 7800GT 256MB GDDR3 PCI-Express Graphics Card
- GeIL 2GB (2x1GB) DDR PC3200 CAS2.5 Dual Channel Memory Kit
- 250GB Western Digital Caviar SE16 16MB Cache SATA-2 Hard Drive
- Pioneer DVR-110BK 16X Dual Layer DVD±RW Black ReWriter Drive
- Onboard 6CH Audio
- 10/100 LAN
- Silverstone Sugo SG01 Case
- Antec NeoHE 430W ATX Power Supply
- Front & Rear Firewire IEEE1394 Connectors
- Front & Rear USB2.0 Ports
- Front Headphone & Microphone Ports
£1145
or
Ultima" AMD Athlon 64 3700 Dual DDR System (FS-004-OC)
AMD Athlon 64 3700 San Diego (Socket 939) Dual DDR400 CPU
- AMD Approved Cooler
- Asus A8N-SLi Premium nForce4 SLi (Socket 939) PCI-Express Motherboard
- GeIL 1GB (2x512MB) DDR PC3200 CAS2.5 Dual Channel Kit
- 250GB Western Digital Caviar SE16 16mb cache SATA-2 Hard Drive
- Leadtek GeForce 7800 GTX 256MB DDR3 PCI-Express Graphics Card
- Pioneer DVR-110 16 x 16 DVD±RW Dual Layer ReWriter
- Creative Sound Blaster Audigy 4.0 Sound Card
- Mitsumi FA 404M 7in1 USB 2.0 Floppy & Media Drive - Silver
- Coolermaster Silver WaveMaster Case
- Tagan TG580-U15 580W ATX2.01 Easycon SLi Compliant Modular Silent PSU
£1115.
I want to order this asap but i am not sure which one to order. Any advice greatly appreciated.
Cheers everyone
Depends what you want to do, I'd probably go for the top one though as it's dual core so more future proof.
Id go for the bottom one. It will be better for gaming + better sound and power supply unit. Either will be fine with 32 applications if they are loaded with 32bit xp
I'd get the top system as it is dual core and has 2GB ram which will help in games and be more futureproof.
Yes it will run all applications and 32 bit windows fine.
Top one for me also, 2gb ram, dual core will make it nicer when multitasking in windoze or using multithread apps...
Wont be long before all games support dual core as well..
:D
I couldnt find the top one listed on the site its £1380 plus operating system with 2 gt cards in sli..?
The top one is the stronger spec, but the bottom one, (when you take into account the true cost) will perform the same in reality unless you are multitasking your PC. 2gb of memory would be better though, perhaps you can discuss that with ocuk.
