- 27 Jul 2005
- The Orion Spur
Hello guys, I have an old 17inch lcd TV that I want to repair and give to my mum, I've cracked up the case and think I've found the problem below which is a picture of a cap on the power inverter that I've removed from inside the screen, I thought it may of been a cap as before the screen started to fail I was hearing hissing.
Anyway here is the suspect cap,
Now I've googled "1000uf 16v capacitor" and found these on the bay,
I'm guessing they will be fine as a replacement yes ?
High quality, low cost, radial lead aluminium electrolytic capacitors
Long life - endurance tested to 2000 hours at 85 degrees C.
* Tolerance +/- 20% at 120Hz, 20 degC.
* Ripple current 720mA.
* Operating temp -40 to +85 degC.
* Leakage current <0.01CV
* Lead pitch 5mm
* Body diameter 10mm
* Height 16mm.
