Help needed! Setting up a IPv6 Gateway
2 Nov 2005
Leicester
*** Warning networking geeky knowlege needed for this! ***
I have recently put together a small Intel Atom server as a gateway and installed Ubuntu Server onto its little 4GB SSD.
It has two NIC's, one on the motherboard (eth0) which is the Internet and A PCI NIC (eth1) which goes out to a gigabit switch and from there all the desktops, laptops etc.
It is running Ubuntu Server 10.10 32bit.
I have set up ufw (Ubuntu's 'uncomplicated firewall') which handles the port filtering and masquerading. It works great for IPv4 (masquerading is working!) but I have problems using it with IPv6 as I will explain later.
I have also set it up with a Hurricane Electric IPv6 tunnel from http://tunnelbroker.net/. I have gotten radvd to send out the IPv6 addresses correctly and the IPv6 connection is working fine on the gateway itself.
The problems start when I try to access a website from an external device such as my laptop. It manages to resolve the IPv6 address of say ipv6.google.com just fine but gets stuck on connecting... and eventually fails.
ufw might be blocking it or I might of just set the whole thing up wrong, I've spent hours searching the web for solutions and tried all sorts of things :(
Here is my log output and config files etc: (warning large amount of text!)
tail /var/log/syslog while connecting to IPv6 website:
Code:
gateway@gateway:~$ tail /var/log/syslog
Jan 27 20:42:37 gateway kernel: [ 1949.847386] [UFW BLOCK] IN=he-ipv6 OUT= MAC=70:71:bc:bc:72:e7:00:23:cd:b0:5a:6e:08:00:45:00:00:ec:00:00:40:00:f7:29:8f:d4:d8:42:50:1a:c0:a8:0a:0f:60:00:00:00:00:b0:3a:40:fe:80:00:00:00:00:00:00:00:00:00:00:d8:42:50:1a:fe:80:00:00:00:00:00:00:00:00:00:00:c0:a8:14:fd:01:02:68:49:00:00:00:00:60:00:00:00:00:80:3a:ff:fe:80:00:00:00:00:00:00:00:00:00:00:c0:a8:14:fd:2a:00:14:50:80:06:00:00:00:00:00:00:00:00:00:93:89:00:63:64:00:00:00:00:20:01:04:70:1f:09:10:e7:d4:d1:f2:05:65:fc:84:94:20:01 TUNNEL=216.66.80.26->192.168.10.15 SRC=fe80:0000:0000:0000:0000:0000:d842:501a DST=fe80:0000:0000:0000:0000:0000:c0a8:14fd LEN=216 TC=0 HOPLIMIT=64 FLOWLBL=0 PROTO=ICMPv6 TYPE=1 CODE=2 [SRC=fe80:0000:0000:0000:0000:0000:c0a8:14fd DST=2a00:1450:8006:0000:0000:0000:0000:0093 LEN=168 TC=0 HOPLIMIT=255 FLOWLBL=0 PROTO=ICMPv6 TYPE=137 CODE=0 ]
Jan 27 20:42:37 gateway kernel: [ 1949.882095] [UFW BLOCK] IN=he-ipv6 OUT= MAC=70:71:bc:bc:72:e7:00:23:cd:b0:5a:6e:08:00:45:00:00:ec:00:00:40:00:f7:29:8f:d4:d8:42:50:1a:c0:a8:0a:0f:60:00:00:00:00:b0:3a:40:fe:80:00:00:00:00:00:00:00:00:00:00:d8:42:50:1a:fe:80:00:00:00:00:00:00:00:00:00:00:c0:a8:14:fd:01:02:68:49:00:00:00:00:60:00:00:00:00:80:3a:ff:fe:80:00:00:00:00:00:00:00:00:00:00:c0:a8:14:fd:2a:00:14:50:80:06:00:00:00:00:00:00:00:00:00:93:89:00:63:66:00:00:00:00:20:01:04:70:1f:09:10:e7:d4:d1:f2:05:65:fc:84:94:20:01 TUNNEL=216.66.80.26->192.168.10.15 SRC=fe80:0000:0000:0000:0000:0000:d842:501a DST=fe80:0000:0000:0000:0000:0000:c0a8:14fd LEN=216 TC=0 HOPLIMIT=64 FLOWLBL=0 PROTO=ICMPv6 TYPE=1 CODE=2 [SRC=fe80:0000:0000:0000:0000:0000:c0a8:14fd DST=2a00:1450:8006:0000:0000:0000:0000:0093 LEN=168 TC=0 HOPLIMIT=255 FLOWLBL=0 PROTO=ICMPv6 TYPE=137 CODE=0 ]
Jan 27 20:42:37 gateway kernel: [ 1949.917462] [UFW BLOCK] IN=he-ipv6 OUT= MAC=70:71:bc:bc:72:e7:00:23:cd:b0:5a:6e:08:00:45:00:00:ec:00:00:40:00:f7:29:8f:d4:d8:42:50:1a:c0:a8:0a:0f:60:00:00:00:00:b0:3a:40:fe:80:00:00:00:00:00:00:00:00:00:00:d8:42:50:1a:fe:80:00:00:00:00:00:00:00:00:00:00:c0:a8:14:fd:01:02:68:49:00:00:00:00:60:00:00:00:00:80:3a:ff:fe:80:00:00:00:00:00:00:00:00:00:00:c0:a8:14:fd:2a:00:14:50:80:06:00:00:00:00:00:00:00:00:00:93:89:00:63:68:00:00:00:00:20:01:04:70:1f:09:10:e7:d4:d1:f2:05:65:fc:84:94:20:01 TUNNEL=216.66.80.26->192.168.10.15 SRC=fe80:0000:0000:0000:0000:0000:d842:501a DST=fe80:0000:0000:0000:0000:0000:c0a8:14fd LEN=216 TC=0 HOPLIMIT=64 FLOWLBL=0 PROTO=ICMPv6 TYPE=1 CODE=2 [SRC=fe80:0000:0000:0000:0000:0000:c0a8:14fd DST=2a00:1450:8006:0000:0000:0000:0000:0093 LEN=168 TC=0 HOPLIMIT=255 FLOWLBL=0 PROTO=ICMPv6 TYPE=137 CODE=0 ]
Jan 27 20:42:37 gateway kernel: [ 1949.951630] [UFW BLOCK] IN=he-ipv6 OUT= MAC=70:71:bc:bc:72:e7:00:23:cd:b0:5a:6e:08:00:45:00:00:ec:00:00:40:00:f7:29:8f:d4:d8:42:50:1a:c0:a8:0a:0f:60:00:00:00:00:b0:3a:40:fe:80:00:00:00:00:00:00:00:00:00:00:d8:42:50:1a:fe:80:00:00:00:00:00:00:00:00:00:00:c0:a8:14:fd:01:02:68:49:00:00:00:00:60:00:00:00:00:80:3a:ff:fe:80:00:00:00:00:00:00:00:00:00:00:c0:a8:14:fd:2a:00:14:50:80:06:00:00:00:00:00:00:00:00:00:93:89:00:63:6a:00:00:00:00:20:01:04:70:1f:09:10:e7:d4:d1:f2:05:65:fc:84:94:20:01 TUNNEL=216.66.80.26->192.168.10.15 SRC=fe80:0000:0000:0000:0000:0000:d842:501a DST=fe80:0000:0000:0000:0000:0000:c0a8:14fd LEN=216 TC=0 HOPLIMIT=64 FLOWLBL=0 PROTO=ICMPv6 TYPE=1 CODE=2 [SRC=fe80:0000:0000:0000:0000:0000:c0a8:14fd DST=2a00:1450:8006:0000:0000:0000:0000:0093 LEN=168 TC=0 HOPLIMIT=255 FLOWLBL=0 PROTO=ICMPv6 TYPE=137 CODE=0 ]
Jan 27 20:42:37 gateway kernel: [ 1949.971056] [UFW BLOCK] IN=he-ipv6 OUT= MAC=70:71:bc:bc:72:e7:00:23:cd:b0:5a:6e:08:00:45:00:00:ec:00:00:40:00:f7:29:8f:d4:d8:42:50:1a:c0:a8:0a:0f:60:00:00:00:00:b0:3a:40:fe:80:00:00:00:00:00:00:00:00:00:00:d8:42:50:1a:fe:80:00:00:00:00:00:00:00:00:00:00:c0:a8:14:fd:01:02:68:49:00:00:00:00:60:00:00:00:00:80:3a:ff:fe:80:00:00:00:00:00:00:00:00:00:00:c0:a8:14:fd:2a:00:14:50:80:06:00:00:00:00:00:00:00:00:00:93:89:00:63:62:00:00:00:00:20:01:04:70:1f:09:10:e7:d4:d1:f2:05:65:fc:84:94:20:01 TUNNEL=216.66.80.26->192.168.10.15 SRC=fe80:0000:0000:0000:0000:0000:d842:501a DST=fe80:0000:0000:0000:0000:0000:c0a8:14fd LEN=216 TC=0 HOPLIMIT=64 FLOWLBL=0 PROTO=ICMPv6 TYPE=1 CODE=2 [SRC=fe80:0000:0000:0000:0000:0000:c0a8:14fd DST=2a00:1450:8006:0000:0000:0000:0000:0093 LEN=168 TC=0 HOPLIMIT=255 FLOWLBL=0 PROTO=ICMPv6 TYPE=137 CODE=0 ]
Jan 27 20:42:47 gateway kernel: [ 1960.071997] [UFW BLOCK] IN=he-ipv6 OUT= MAC=70:71:bc:bc:72:e7:00:23:cd:b0:5a:6e:08:00:45:00:00:ec:00:00:40:00:f7:29:8f:d4:d8:42:50:1a:c0:a8:0a:0f:60:00:00:00:00:b0:3a:40:fe:80:00:00:00:00:00:00:00:00:00:00:d8:42:50:1a:fe:80:00:00:00:00:00:00:00:00:00:00:c0:a8:14:fd:01:02:68:49:00:00:00:00:60:00:00:00:00:80:3a:ff:fe:80:00:00:00:00:00:00:00:00:00:00:c0:a8:14:fd:2a:00:14:50:80:06:00:00:00:00:00:00:00:00:00:93:89:00:63:62:00:00:00:00:20:01:04:70:1f:09:10:e7:d4:d1:f2:05:65:fc:84:94:20:01 TUNNEL=216.66.80.26->192.168.10.15 SRC=fe80:0000:0000:0000:0000:0000:d842:501a DST=fe80:0000:0000:0000:0000:0000:c0a8:14fd LEN=216 TC=0 HOPLIMIT=64 FLOWLBL=0 PROTO=ICMPv6 TYPE=1 CODE=2 [SRC=fe80:0000:0000:0000:0000:0000:c0a8:14fd DST=2a00:1450:8006:0000:0000:0000:0000:0093 LEN=168 TC=0 HOPLIMIT=255 FLOWLBL=0 PROTO=ICMPv6 TYPE=137 CODE=0 ]
Jan 27 20:42:47 gateway kernel: [ 1960.107258] [UFW BLOCK] IN=he-ipv6 OUT= MAC=70:71:bc:bc:72:e7:00:23:cd:b0:5a:6e:08:00:45:00:00:ec:00:00:40:00:f7:29:8f:d4:d8:42:50:1a:c0:a8:0a:0f:60:00:00:00:00:b0:3a:40:fe:80:00:00:00:00:00:00:00:00:00:00:d8:42:50:1a:fe:80:00:00:00:00:00:00:00:00:00:00:c0:a8:14:fd:01:02:68:49:00:00:00:00:60:00:00:00:00:80:3a:ff:fe:80:00:00:00:00:00:00:00:00:00:00:c0:a8:14:fd:2a:00:14:50:80:06:00:00:00:00:00:00:00:00:00:93:89:00:63:64:00:00:00:00:20:01:04:70:1f:09:10:e7:d4:d1:f2:05:65:fc:84:94:20:01 TUNNEL=216.66.80.26->192.168.10.15 SRC=fe80:0000:0000:0000:0000:0000:d842:501a DST=fe80:0000:0000:0000:0000:0000:c0a8:14fd LEN=216 TC=0 HOPLIMIT=64 FLOWLBL=0 PROTO=ICMPv6 TYPE=1 CODE=2 [SRC=fe80:0000:0000:0000:0000:0000:c0a8:14fd DST=2a00:1450:8006:0000:0000:0000:0000:0093 LEN=168 TC=0 HOPLIMIT=255 FLOWLBL=0 PROTO=ICMPv6 TYPE=137 CODE=0 ]
Jan 27 20:42:47 gateway kernel: [ 1960.143516] [UFW BLOCK] IN=he-ipv6 OUT= MAC=70:71:bc:bc:72:e7:00:23:cd:b0:5a:6e:08:00:45:00:00:ec:00:00:40:00:f7:29:8f:d4:d8:42:50:1a:c0:a8:0a:0f:60:00:00:00:00:b0:3a:40:fe:80:00:00:00:00:00:00:00:00:00:00:d8:42:50:1a:fe:80:00:00:00:00:00:00:00:00:00:00:c0:a8:14:fd:01:02:68:49:00:00:00:00:60:00:00:00:00:80:3a:ff:fe:80:00:00:00:00:00:00:00:00:00:00:c0:a8:14:fd:2a:00:14:50:80:06:00:00:00:00:00:00:00:00:00:93:89:00:63:66:00:00:00:00:20:01:04:70:1f:09:10:e7:d4:d1:f2:05:65:fc:84:94:20:01 TUNNEL=216.66.80.26->192.168.10.15 SRC=fe80:0000:0000:0000:0000:0000:d842:501a DST=fe80:0000:0000:0000:0000:0000:c0a8:14fd LEN=216 TC=0 HOPLIMIT=64 FLOWLBL=0 PROTO=ICMPv6 TYPE=1 CODE=2 [SRC=fe80:0000:0000:0000:0000:0000:c0a8:14fd DST=2a00:1450:8006:0000:0000:0000:0000:0093 LEN=168 TC=0 HOPLIMIT=255 FLOWLBL=0 PROTO=ICMPv6 TYPE=137 CODE=0 ]
Jan 27 20:42:47 gateway kernel: [ 1960.178958] [UFW BLOCK] IN=he-ipv6 OUT= MAC=70:71:bc:bc:72:e7:00:23:cd:b0:5a:6e:08:00:45:00:00:ec:00:00:40:00:f7:29:8f:d4:d8:42:50:1a:c0:a8:0a:0f:60:00:00:00:00:b0:3a:40:fe:80:00:00:00:00:00:00:00:00:00:00:d8:42:50:1a:fe:80:00:00:00:00:00:00:00:00:00:00:c0:a8:14:fd:01:02:68:49:00:00:00:00:60:00:00:00:00:80:3a:ff:fe:80:00:00:00:00:00:00:00:00:00:00:c0:a8:14:fd:2a:00:14:50:80:06:00:00:00:00:00:00:00:00:00:93:89:00:63:68:00:00:00:00:20:01:04:70:1f:09:10:e7:d4:d1:f2:05:65:fc:84:94:20:01 TUNNEL=216.66.80.26->192.168.10.15 SRC=fe80:0000:0000:0000:0000:0000:d842:501a DST=fe80:0000:0000:0000:0000:0000:c0a8:14fd LEN=216 TC=0 HOPLIMIT=64 FLOWLBL=0 PROTO=ICMPv6 TYPE=1 CODE=2 [SRC=fe80:0000:0000:0000:0000:0000:c0a8:14fd DST=2a00:1450:8006:0000:0000:0000:0000:0093 LEN=168 TC=0 HOPLIMIT=255 FLOWLBL=0 PROTO=ICMPv6 TYPE=137 CODE=0 ]
Jan 27 20:42:48 gateway kernel: [ 1960.214946] [UFW BLOCK] IN=he-ipv6 OUT= MAC=70:71:bc:bc:72:e7:00:23:cd:b0:5a:6e:08:00:45:00:00:ec:00:00:40:00:f7:29:8f:d4:d8:42:50:1a:c0:a8:0a:0f:60:00:00:00:00:b0:3a:40:fe:80:00:00:00:00:00:00:00:00:00:00:d8:42:50:1a:fe:80:00:00:00:00:00:00:00:00:00:00:c0:a8:14:fd:01:02:68:49:00:00:00:00:60:00:00:00:00:80:3a:ff:fe:80:00:00:00:00:00:00:00:00:00:00:c0:a8:14:fd:2a:00:14:50:80:06:00:00:00:00:00:00:00:00:00:93:89:00:63:6a:00:00:00:00:20:01:04:70:1f:09:10:e7:d4:d1:f2:05:65:fc:84:94:20:01 TUNNEL=216.66.80.26->192.168.10.15 SRC=fe80:0000:0000:0000:0000:0000:d842:501a DST=fe80:0000:0000:0000:0000:0000:c0a8:14fd LEN=216 TC=0 HOPLIMIT=64 FLOWLBL=0 PROTO=ICMPv6 TYPE=1 CODE=2 [SRC=fe80:0000:0000:0000:0000:0000:c0a8:14fd DST=2a00:1450:8006:0000:0000:0000:0000:0093 LEN=168 TC=0 HOPLIMIT=255 FLOWLBL=0 PROTO=ICMPv6 TYPE=137 CODE=0 ]
gateway@gateway:~$
sudo ufw status
Code:
gateway@gateway:~$ sudo ufw status
Status: active
To                         Action      From
546                        ALLOW       Anywhere
547                        ALLOW       Anywhere
41                         ALLOW       Anywhere
22                         ALLOW       Anywhere
67                         ALLOW       Anywhere
68                         ALLOW       Anywhere
53                         ALLOW       Anywhere
Anywhere                   ALLOW       95.172.230.195/ipv6
Anywhere                   ALLOW       216.66.80.26/ipv6
7                          ALLOW       Anywhere
546                        ALLOW       Anywhere (v6)
547                        ALLOW       Anywhere (v6)
41                         ALLOW       Anywhere (v6)
22                         ALLOW       Anywhere (v6)
67                         ALLOW       Anywhere (v6)
68                         ALLOW       Anywhere (v6)
53                         ALLOW       Anywhere (v6)
gateway@gateway:~$
cat /etc/network/interfaces
Code:
gateway@gateway:~$ cat /etc/network/interfaces
auto lo
iface lo inet loopback
auto eth0
iface eth0 inet dhcp
auto eth1
iface eth1 inet static
        address 192.168.20.253
        netmask 255.255.255.0
        network 192.168.20.0
        broadcast 192.168.20.255
auto he-ipv6
iface he-ipv6 inet6 v4tunnel
     endpoint 216.66.80.26
     address  2001:470:1f08:10e7::2
     netmask  64
     up ip -6 route add default dev he-ipv6
     down ip -6 route del default dev he-ipv6
gateway@gateway:~$
ifconfig
Code:
gateway@gateway:~$ ifconfig
eth0      Link encap:Ethernet  HWaddr 70:71:bc:bc:72:e7
          inet addr:192.168.10.15  Bcast:192.168.10.255  Mask:255.255.255.0
          inet6 addr: fe80::7271:bcff:febc:72e7/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:6782 errors:0 dropped:0 overruns:0 frame:0
          TX packets:5933 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:6434248 (6.4 MB)  TX bytes:993571 (993.5 KB)
          Interrupt:44 Base address:0x2000
eth1      Link encap:Ethernet  HWaddr 00:1f:1f:e9:99:c6
          inet addr:192.168.20.253  Bcast:192.168.20.255  Mask:255.255.255.0
          inet6 addr: fe80::21f:1fff:fee9:99c6/64 Scope:Link
          RX packets:1719 errors:0 dropped:0 overruns:0 frame:0
          TX packets:976 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:250412 (250.4 KB)  TX bytes:653333 (653.3 KB)
          Interrupt:20 Base address:0x6000
he-ipv6   Link encap:IPv6-in-IPv4
          inet6 addr: fe80::c0a8:14fd/64 Scope:Link
          inet6 addr: 2001:470:1f08:10e7::2/64 Scope:Global
          UP POINTOPOINT RUNNING NOARP  MTU:1480  Metric:1
          RX packets:777 errors:0 dropped:0 overruns:0 frame:0
          TX packets:772 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:563617 (563.6 KB)  TX bytes:105701 (105.7 KB)
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:72 errors:0 dropped:0 overruns:0 frame:0
          TX packets:72 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:13659 (13.6 KB)  TX bytes:13659 (13.6 KB)
gateway@gateway:~$
cat /etc/radvd.conf
Code:
gateway@gateway:~$ cat /etc/radvd.conf
interface eth1
   AdvSendAdvert on;
   prefix 2001:470:1f09:10e7::/64
        AdvOnLink on;
        AdvAutonomous on;
        AdvRouterAddr on;
gateway@gateway:~$
ip -6 route show
Code:
gateway@gateway:~$  ip -6 route show
2001:470:1f08:10e7::/64 via :: dev he-ipv6  proto kernel  metric 256  mtu 1480 advmss 1420 hoplimit 0
fe80::/64 dev eth1  proto kernel  metric 256  mtu 1500 advmss 1440 hoplimit 0
fe80::/64 dev eth0  proto kernel  metric 256  mtu 1500 advmss 1440 hoplimit 0
fe80::/64 via :: dev he-ipv6  proto kernel  metric 256  mtu 1480 advmss 1420 hoplimit 0
default dev he-ipv6  metric 1024  mtu 1480 advmss 1420 hoplimit 0
If you need any more output let me know :)
At a glance, your config looks right, and your firewall is blocking packets. Can you try disabling ufw temporarily (allow all everywhere) and see if it works then?
I did something similar just under a year ago with an atom board (http://www.madeo.co.uk/?p=452), but with centos, ufw looks a lot more friendly than iptables...
If you haven't allready you'll want to enable ipv6 (proto 41) something like this `sudo ufw allow proto ipv6 from x.x.x.x`
A little reading : http://en.wikipedia.org/wiki/6to4
Turn logging on with `sudo ufw logging on`, and have a look in the logs to see if the firewall is not intercepting ipv6 anymore!
First question. Is the laptop recieving the Ipv6 prefix, configuring its IP and installing the default route for IPv6? DNS answers are independant of the transport used to query them, so you may get the answer for ipv6.google.com without any actual connectivity.
Sorry for late reply, been out most of today.
I tried disabling the firewall, it did not seem to help with the IPv6 problems.
I have 41 ALLOW Anywhere (v6), would sudo ufw allow proto ipv6 from x.x.x.x make a difference?
and what IP do I use for "x.x.x.x"? Is the the IPv4 IP of the tunnel server?
If you look at the syslog, it seems the firewall was only blocking ICMPv6 packets?? Isnt that just what ping uses?
From the pictures below, it appears it has found the gateway with radvd running on it and connected into it with the settings it provided.
These pics are from my laptop connected straight into eth1 of the gateway, see origional post for meaning of eth0, eth1 etc.
BINGO! Took days of hard labour to figure this out!!!!
I added this to my /etc/network/interfaces:
auto eth1
.... ipv4 stuff here ...
up ip -6 addr add <routed 64 prefix from tunnel website>::<unique number here>/64 dev eth1
up ip -6 route add <ipv6 address of your tunnel (you can find it in ifconfig/he-ipv6)>/64 dev eth1
down ip -6 addr del <routed 64 prefix from tunnel website>::<unique number here>/64 dev eth1
down ip -6 route del <ipv6 address of your tunnel (you can find it in ifconfig/he-ipv6)>/64 dev eth1
I figured it out with some guess work and also from a reply on another forum that says:
eth0 and eth1 don't have IPv6 addresses assigned to them...assign them an address from your routed /64 (or if they're on different subnets, from the /48)
He was only half right, eth0 didnt need an ipv6 address. only eth1 needed one, and I didnt need a /48, 64 seems to work fine.
I really hope this helps someone. Was the hardest networking problem ive had. If only there was more good info like this on the internet!
Christ .... this is so year 2000 !
Google IPv6 over IPv4 / http://en.wikipedia.org/wiki/List_of_IPv6_tunnel_brokers
It's good fun setting up and learning I suppose but all that effort just to see kame dance ? :/
Yes, there is a lot more to it than finding a tunnel broker :) I already mentioned a very good one in the original post. I have learnt a lot about networking from this which could help me in future with career etc.
It was worth it and the gateway can perform other tasks too as long as they are within cpu/space constraints. It means I can move the file server to a more suitable location in the house since it does not have to perform gateway duties (and only needs one NIC), also added some redundancy which is always good :)
I noticed a big increase in my browsing speed since the browser can more easily access the ever increasing amount of IPv6 capable websites.
You're not going to get a job with basic network skills ... Learn something useful that pays like bgp, cisco, protocols ... start here
http://en.wikipedia.org/wiki/Routing_protocol
Yep I found it faster last time I used it 10 years back but there's not much out there on the dark side, anything changed in terms of torrents. nntp, websites etc ?
BTW did you resolve your ip6tables problems ?
yeah firewall was fine all is still working good. Its very fast. There are a few more IPv6 capable sites now and I see about 10% of my traffic going over IPv6 now.
I recommend other people try this! All you need is a little low power pc like intel atom with room for an additional NIC card.
