Help needed to choose a cheap HDMI Graphics Card please
11 Jun 2004
Middlesex, London
Hi all,
I'm after a PCI-E HDMI graphics card please - Cheap as possible.
Must be able to play HD material - i.e. Blu-Ray's and H.264 / MKV files
What do you suggest?
Thanks
ati hd 3450 or hd4350 for £25-£35 also avialable with hdmi out if you look out otherwise dvi with usually optional hdmi to dvi converter
at the really cheap end there is older often dell oem hd 2400's for £15 but dvi ratehr than hdmi
Thanks
The audio will also go through these cards right? so just need the one HDMI cable going from the PC to the HD TV?
Thanks
Yep, You'll need the official Ati DVI to HDMI adaptor (not all ATi cards come with them, especially the cheaper ones.)
....so on a model with actual HDMI port on board (do they exist ??) the sound is already 'wired in' ?
My MCE machine oem gfx card (7600GTL - some wierd Sony effort !!) seems to be dying....it has HDMI output only, but I have to separately wire audio out :( - still if these little 34xx cards support audio too, could be great time to swap out !
