help needed to connect a tablet to a smart tv via usb
2 Jul 2007
Cheshire East
Hi all
Bought a lenovo A3500-F tablet yesterday and want to connect it to my smart tv with a usb to hdmi cable...is this possible...and if so what else would i need to do it.
thx
All the specs and reviews online say it does not have HDMI capabilities :(
If your smart TV allows screen casting, you should be able to use that from the tablet :)
the guy at the shop said that i could connect it with a usb to hdmi cable...are you saying that I can not use the mini usb port on the tablet to stream video to the hdmi on the tv...with a cable/adapter...
I'm not saying that, the web is. It would appear your only chance is using your smart tv as an active display. The usb port needs to be mhl or slimport compatible, and it does not appear to be.
Sorry.
update
had to return the tab 4 as that is not compatible either.
Amy one know much about the linx 8 tablet or the teclast P10HD...they both have mini hdmi so would work but dont know which would be best
thanks
