Hi,
Just picked up a set of corsair vengence lpx ram sticks at 3200Mhz CL16 with the timings 16-20-20-38 (to my surprise it is the E die model
so looking to adjust the timings).
I know you can set the timings differently but just looking for some help on what timings and voltages to set them at to start with as I will be 'downclocking' (not the correct term) them to 2666Mhz as this is all my 10th gen i5 will support.
So my question is: What timings should I be able to get out of these sticks at 2666MHz?
Do you think 15-17-17-36 be achievable?
System Specs:
CPU: 10400
MoBo: H470m-itx/ac
Cheers,
TJ
System Specs:
CPU: 10400
MoBo: H470m-itx/ac
Cheers,
TJ
