Help needed with building watercooling setup
5 Oct 2011
Hi everyone,
I always come post whenever I need some help regarding builds and I always get very good help, for that I am very grateful. On with the post.
I am looking to make my pc watercooled. I have had some watercooling setup long ago but I am totally out of the loop on what's good with brands and setups. I have an NZXT Phantom tower and a 2500k Processor. I would like to get a setup for my current build but upgradeable to include a GPU waterblock.
So gentlemen, could you please advise for the following:
  • CPU waterblock
  • Radiator(Phantom case can hold a 3 120mm radiator afaik)
  • Pump/Reservoir
  • Tubing
  • Bits/Connectors
Anything else I may have missed out.
Looking forward to some feedback.
Cheers
Joshua
Hi Snips,
I have not thought about that as I am willing to see what choices I have. Let's start from €250 but can work around it a bit. Maybe that's too little? Let me know, thanks
YOUR BASKET
1 x EK Water Blocks EK-KIT L360 Entry Level Water Cooling Kit £179.99
1 x Phanteks Enthoo Pro Mid Tower Enthusiast Case with Window £89.99
Total : £279.58 (includes shipping : £8.00).
Something like this you may say why a case to but the phantom you may be limited getting extra rads in when you want to expand plus the entho has dedicated mount spots for pump/res and such, the kits is great as it comes with everything you need, I use a D5 myself but a lot of people say the EK pumps are just as good.
I am willing to stretch, I just put a price there. My main problem is noise, I would want not want the hum of the pump if possible. I do like black fittings to complement the white case.
Well in terms of noise I'd say D5's are silent on the right setting and if you put them on some foam all the better.
Here's different Black fittings, I have the monsoon, only because I couldn't stomach the Bitspower cost.
YOUR BASKET
1 x Bitspower Premium G1/4" Black Sparkle High Flow 3/8" (5/8") Compression Fitting £8.95
1 x Bitspower Premium G1/4" Matte Black High Flow 3/8" (1/2" OD) Compression Fitting £6.98
1 x Monsoon 13/10mm (ID 3/8 OD 1/2) Free Center Compression Fitting - Matte Black £5.29
1 x EK Water Blocks EK-CSQ Fitting 10/13mm G1/4 - Black £2.99
1 x XSPC G1/4" to 3/8" ID, 1/2" OD Compression Fitting (Black Chrome) £2.99
Total : £31.12 (includes shipping : £3.26).
They look rly nice- especially the Bitspower! So 1/2" tubing should be ok for those fittings right? Also, how powerful does a pump need to be to cool a cpu and possibly a vga later on?
D5 pump would do it no problem, Not cheapest pump though.
I hear good things about the EK 4.0 pump, but only used a D5 myself so you'd need another's input
The 4.0 is a great pump and can handle 4 or 5 high flow blocks on its own. The new ones are as cheap as the older ones and feature a speed control i believe.
I looked up the 4.0, looks good, does the size of the res have any affect on the performance or is it so it can last longer? Any suggestions for a res?
Hmm then I think we'd need to think routing and Space.
a tube/pump combo is great for saving space & money.
I went separate, but that means you need more room I've not got a clear pic in my head ATM.
Is the case you linked the exact model you have?
