- 28 Jul 2004
- london
Hi all i hope someone can give me any advice on a problem i seem to be having.
Firstlt the components i have are.
CPU
Name Intel Core 2 Quad Q6600
Codename Kentsfield
Specification Intel(R) Core(TM)2 Quad CPU @ 2.40GHz
Package Socket 775 LGA (platform ID = 4h)
CPUID 6.F.7
Extended CPUID 6.F
Core Stepping B3
Technology 65 nm
Core Speed 1600.1 MHz (6.0 x 266.7 MHz)
Rated Bus speed 1066.7 MHz
Stock frequency 2400 MHz
Heatsink.
Artic Cooling Freezer Pro 7
Motherbord
Asus Commando
Bios Commando1703.ROM
Ok the problem i am having is that when i boot in to the bios the temp is showing me 42 degrees and when i boot in to windows CoreTemp is showing me that core0 is at 50/52 Degrees and the other three cores are at 42 degrees at idle. I do not think that this is to good.
The bios is set to defualt settings so no overclock as far as i know. Basicly i am worried incase 1. my cpu is damaged or something else is wrong.
Can anyone give me some feedback on what i should be seeing temp wise or if i have missed something.
Thanks in Advance.
/mark.
CPU
Codename Kentsfield
CPUID 6.F.7
Extended CPUID 6.F
Core Stepping B3
Technology 65 nm
Heatsink.
Motherbord
Asus Commando
Thanks in Advance.
/mark.
