- 8 Mar 2007
- Poole, Dorset.
Well its my mum has the problem, she has 10meg broadband cable modem which is connected in the livingroom, but her pc is in the back room and has a 20 mtre cable running from modem to pc for her internet connection.
She has had this setup for over 2years, so the cable is starting to split and showing the internal wires and may cause problems later.
I`ve told her to go wireless, but the internet provider will charge £40 to go wireless or £40 for a replacement cable and she doesn`t want to pay this.
I can cut out the bad part of the cable, but what would I need to use to join the ethernet cable back together and how to do it?
Thanks!!!!
Thanks!!!!
