I've been holding out for a Haswell upgrade from my old Q6600 quad core, yes I know its old
My budget is between 1200-1400, but naturally i'm looking for the best bang for buck in all components.
I want to build the system around the 4770k CPU and a GTX770 GPU. I would like 16gb ram, SSD, 2tb HD, Case, PSU and a cooling solution.
I would like to overclock to 4.6ghz so need some advice on a good cooling solution.
I don't need any other peripherals, just looking for the fastest box for my money, thanks in advance for any help from the OCUK gurus out there
