I have downloaded and edited this Access Template from Microsoft:
http://office.microsoft.com/en-GB/templates/results.aspx?qu=access&av=zac#ai:TC010222095
I will be using it to keep track of supplier returns policies at work.
I have edited the template at home using Access 2010 but will be using it at work using Access 2007.
What I want to do is be able to double click the database file and it load up the main form with the Main Microsoft Access Window hidden and just the form on show.
After researching I think it is possible using code like this:
http://www.tek-tips.com/faqs.cfm?fid=7522
My question is where do I enter this code in Microsoft Access? From what I can see the site doesn't really explain this. Will this code work with Access 2007? and is this the best way of doing it?
Thanks in Advance!
Thanks in Advance!
There are tools built into Access to let you right VBA scripts. It's been a long time since I did any, but it should be very straightforward.
