Hi all
Iv Just purchaed 2GB Muskin HP after having no luck trying to run 4X512 OCZ platinum Rev2. Apparently due to my older newcastle A64 memory controller not being able to run 4 sticks stable which it didnt.
Anyway installed the ram yesterday and it booted up as normal with settings set to auto in bios 2.3.2.6 1T and all seemed well and stable, untill i tried to benchmark the ram using sisandra05 the system freezed. The same thing happens when i try to play a game etc. it freezes and hangs "very unstable".
I changed a few bios settings and tried 2.6 then 2.7 volts and 2.3.2.6 and 2.3.2.5 and the same thing happens . it seems to run ok doing basic windows operations or brousing the internet, but as soon as you do something demanding the requires memory it just hangs.
I eventually got sissandra to work with a result of
401Mhz 2.3.2.6 and 5979/5876 the same result as my old OCZ Rev2 so it seems to be working ok in that area.
I ran memtest for 1 hour.18.minutes until it frooze with a result off ,,
test 57%, test 8,Testing 108k to 2049m, 2.3.2.6 cas.2 with pass 1 Errors 1255 which was highlighted in Red.
Then ran it overnight for about 8 hours and had the same result with pass 1 and 5000 Errors
Have i got a faulty batch never had any other memory of mine fail memtest. surley my system shoulf be ok with 2x1GB sticks of ram.
Spec
A64 3500+ Newcastle
DFI NF4 SLI-DR
Leadtek 7800GTX
Tagen TG480-U01 PSU
Mushkin 2GB HP 3200 at 2.3.2.6 (also tried 2.3.2.5.)
Thanks in advance
Spec
A64 3500+ Newcastle
DFI NF4 SLI-DR
Leadtek 7800GTX
Tagen TG480-U01 PSU
Thanks in advance
