Hi There,
I have recently bought a W3690 s1366 to go into my Asus P6T (just the standard version)
And with a view to wanting to overclock it I have replaced my Corsair H50 with a custom water cooling loop, and well .. temps are not a problem now
BUT I can't seem to get it to clock to 4.6Ghz without BSOD'ing
It's odd because when I run Real Temp sensor test (prime95 large FFT test) it will complete test #1 at 100% then test#2 at 88.9% but when it starts test #3 it crashes !
I just can't figure that out.
I have tried putting the voltage up to 1.456 with everything else on auto (I tried to change all the other voltages to a little over the standard setting and that made it even worse)
I did have this issue with my 920 in that it wouldn't clock to anything near what most people are clocking them to, so i'm wondering if it's just my mobo that doesn't like overclocking that much.
Does any one have any tried and tested settings for a P6T with a high end i7 or Xeon (for this era of cpu) or any tips for me ?
Or could it be that this mobo isn't a overclocker ?
Any advise gratefully received.
Cheers
DamoB
I should have mentioned my memory:
12 Gb of Corsair Dominator 1600 xms (not using XMS profile) all 6 slots filled.
Cheers
DamoB
