First off, the spec:
Inte5l i7 4770k with stock cooler
Gigabyte windforce nvidea 670
16gb generic ram @ 1333
Wd green 500gb Hdd
750 watt power supply
Cit gaming case with 4 or fans
Windowa 7 64bit
The problem:
I seem to be getting q stutter (multiple very short freezes which affects the video and audio). This typically occurs during high load gaming but also shows itself using youtube and video playback. It is fixed with a reset. Initially I thought it might be heat so I ramped up the pwm slope on the cpu to max and this now tops out at 60ºc (no contoller for case fans, and can't seem to find the way to do this for gpu which hits about 60-65). My second thought is the power supply, whilst it has enough juice, I had to get creative with the connections to make it power everything. Event log shows no criticals, jus a few minor warnings related to my crap wifi.
I am fresh out of ideas, any insights?
Wd green 500gb Hdd
Windowa 7 64bit
The problem:
