help needed with regular expression please
18 Oct 2002
Southampton, Hampshire
being a n00b when it comes to reqular expressions I could do with some help when it comes to conditional string replacement/deletion.
i'm trying to match a string with a word in the middle that could vary. if there is a match then i'd like to remove the end bit after the varying word.
i.e.
msg.setEventType(EventType.OPEN_DOOR.toString()
the text in green is the varying string. i can match it using:
Code:
(setEventType\()(EventType\.).*(toString\(\))
the text in orange is what i'd like to remove.
however my problem comes when it comes to removing the toString() bit - I'm not sure how to do it so that I also keep the text in green.
can anyone help please?
thanks in advance! :)
I mainly use regular expressions in Perl, so this may vary a little between languages.
When you cluster (I think that's the right term) using brackets each part gets put into a special variable, $x, where x is the number of that part e.g $1, $2 etc. You can use these either after the regexp or inside the regexp.
Try this and see if it works:
s/(setEventType\()(EventType\.).*(toString\(\))/$1$2/;
In Perl s/ is the search and replace mechanism. This could vary between different implementations of regular expressions.
Jim
