I am going to building a PC for a friend and wondered if I could get some advice on the below set up. The spec doesn't have to be ground breaking but there are a few small requirements.
The price is to be approx £300 for the below items (case is already owned so not needed)
It needs large storage but preferably a small SSD for the os
It needs HDMI output
It will be fitting in a very small case
I would also like to know if it can be run from a 200w pico PSU or will it need a higher wattage? And if its in a small case will one fan sucking fresh air in and the CPU fan used to expel air via some sort of funnel system?
The specs
Asus P8H61-I Intel H61 (Socket 1155) DDR3 Mini ITX Motherboard (£69.95)
http://www.overclockers.co.uk/showproduct.php?prodid=MB-482-AS&groupid=701&catid=5&subcat=2071
Intel Core i3-2120 3.30GHz (Sandybridge) Socket LGA1155 Processor - Retail (£89.99)
http://www.overclockers.co.uk/showproduct.php?prodid=CP-366-IN&groupid=701&catid=6&subcat=1671
GeIL Black Dragon 8GB (2x4GB) DDR3 PC3-10666C9 1333MHz Dual Channel Kit (£25.99)
http://www.overclockers.co.uk/showproduct.php?prodid=MY-118-GL&groupid=701&catid=8&subcat=1516
Samsung SN-208DB/BEBE Slimline 8x DVD±RW SATA Drive - OEM
(£17.99)
http://www.overclockers.co.uk/showproduct.php?prodid=CD-124-SA&groupid=701&catid=10&subcat=952
Crucial V4 64GB 2.5" SATA-II Solid State Hard Drive (£51.99)
http://www.overclockers.co.uk/showproduct.php?prodid=HD-019-CR&groupid=701&catid=2104&subcat=910
Seagate Barracuda 1.5TB SATA GB/s 64MB Cache - OEM (£59.99)
http://www.overclockers.co.uk/showproduct.php?prodid=HD-277-SE&groupid=701&catid=14&subcat=1279
Total £311.90
The specs
(£17.99)
Total £311.90
