Help needed with spraying the front brake discs....(How do i mask it ?)
Caporegime
27 Nov 2005
Guernsey
Most the paint has flaked off the centre of my front/rear brake discs and I want to respray the centre parts again..
But what is the best way to mask up the parts I no want to get any spray paint on With them being round and having all them little circles rivet type parts that hold the disc together??
Picture of a disc (not mine)
If they are alloy then the centers will be anodised rather than painted from new.
To mask, just use standard masking tape and use a small, sharp craft knife to cut around the buttons etc. Don't forget to use a suitable non-ferrous primer if it is alloy (e.g. etch primer).
