Help needed with upgrading watercooling setup
5 Oct 2011
Hi everyone,
I am planning of reintroducing watercooling to my pc again. Had removed it because I had a leak from the cpu Block and removed everything at that time. Now I am buying a new pc and was looking at my current kit, seeing what is salvageable and what is not. By the way I am not too much of a savvy in watercooling so sorry for any noob questions.
http://www.thermaltakeusa.com/Product.aspx?C=1309&ID=1412
This is my case and the following are the parts I have. The waterblock is useless so I will need a new one. I am not sure about the tubing and fittings. Do they need to be replaced? If yes, could you point me to the sizes I would need? Also any other equipment I should look to get could be pointed out.
This is a pic of the pump mainly and fittings:
http://dl.dropbox.com/u/41645151/20120303_132330.jpg
This is the radiator(pls excuse the dust)
http://dl.dropbox.com/u/41645151/20120303_134023.jpg
Looking forward to your replies.
Thanks,
Raziel90
Replace the lot including the rad. Thermaltake's watercooling efforts are rubbish. Skinneelabs did a review on the Thermaltake triple rad and it proved to be a extremely restrictive rad and needed 5x pumps in serial just to hit 1.6GPM. :eek:
