Hi all,
Hoping someone can help me here. I have a Sony HC39E Digital Camcorder that is widescreen. I capture my raw .avi using Pinnacle Home Studio and it all looks great in 16:9 within Pinnacle. I can also play the raw .avi using Windows Media Player and it maintains the 16:9 ratio.
However, if I want to compress this footage, using something like Virtual Dub and any codec such as DivX, the video is output as 4:3 and is all out of proportion. I have looked through all the Virtual Dub settings and cannot see anything to tell it that the footage is widescreen.
If I use AVIcodec to interrogate the raw captured .avi it tells me that the video is 720x576 (4:3), but if I remember correctly all widescreen videos are actually 4:3, but some 'tag' within the file tells the media player to stretch it out to make it appear correct in 16:9.
Anyway, if someone could advise how I can maintain the 16:9 using Virtual Dub or recommend some other software that does do it I would be grateful.
Cheers
Cheers
