Help Needed
31 Mar 2009
Stoke-on-trent
i've been asked to look at a computer for a friend as it doesn't work.
He kept getting the blue screen and now the computer wont boot up.
I've removed everything apart from the main hard drive but can't get the monitor to come on.
Any ideas?
Cheers
Perfect
lmao - i tried every which way - but always with the hard drive plugged in - cheers
need help now getting the system back up and running
everything now starts up even the screen, but how do i go about reconnecting the hard drives etc...
all i get on screen is -
reboot and select proper boot device
it's a fairly old system using ide drives.
right - i've found the drive loaded with windows - it loads up normal but then says windows could not start because the following file is missing or corrupt
system32\drivers\pci.sys
yeah hp.
i think something that was inside has broken, as he kept getting blue screens, so if/when this restore works, i'll be adding everything until it keeps crashing again.
Then i'll know whats the problem. :)
