Hi all,
Please help. A couple of years ago i built my first pc, everything perfect. However, now when i have come to upgrade there are a few problems. I've bought a new cpu, mobo and ram.
I built everything up, and it just wont boot, it doesn't even reach the bios. All the fans spin, but nothing. It doesn't make any beep noise on startup. Then it will turn itself off?
Spec:
New parts:
Gigabyte GA-M52L-S3P nForce 520LE Socket AM2+ 8 Channel Audio ATX Motherboard
OCZ 4GB (2x2GB) DDR2 800Mhz/PC2-6400 GOLD XTC Memory Kit CL5(5-5-5-18)
AMD Phenom X4 9650 2.3GHz Socket AM2+ 2MB L3 Cache Retail Boxed Processor
Old parts:
450W Antec PSU
nVidia 7800 GTX PCI-E card
I have tested that ram in another computer and that works fine. The graphics card worked with the old setup, so i can't see that being the problem. Which leaves me with the mobo or the cpu. Is there any way to tell what is causing the problem without actually trying a different cpu or mobo as i don't have any compatible. Or what it is most likely to be.
My thoughts are I have a faulty mobo, not sure though.
Please help.
Thanks
Spec:
New parts:
Old parts:
450W Antec PSU
Please help.
Thanks
