help needed
2 Aug 2006
Liverpool
hi i'm getting a lot of bsod with the message memory management, i'm thinking it's my ram but not certain as i've checked it overnight and it passed but don't know what else it could be, any suggestions?
thanks
Paul Ryan
Ok, try using the system with one stick of RAM at a time. Try testing a different stick and different banks but make one change at a timeso make a log of what you are doing.
If the BSOD appears with the same stick regardless of what bank it's in, then you have a faulty memory module.
If different modules fail in the same bank, then it looking to be either a CPU (probably with the MC) or the motherboard..
Ok, try using the system with one stick of RAM at a time. Try a different stick and different banks but make one change at a time. If the BSOD appears with the same stick regardless of the bank it's in you have a faulty memory module.
If different modules fail in the same bank, then it looking to be either a CPU problem, probably with the MC or the motherboard..
thanks for the suggestions but unfortunately i can't do my own pc maintenance due to my disability
