Help needed!
14 Dec 2017
Aberdeenshire
I am trying to make a spreadsheet which i thought would be a simple spreadsheet, maybe is but i cant get my head around something.
its a spreadsheet that counts the days i am home and away and also counts my wages.
work column is the days i am away calculated by each x
home is calculated by each space left blank
500 column is my day rate (just for illustration) but its basically a duplicate column that i dont want i just needed to put in a number at the top so for the next total column i had a number to multiply by to get an answer so in cell AJ3 i have =AI2*$AI$3
is there a way to have cell AG2 hold the value 500 but still say work so i can get rid of the extra row but still have something to multiply by?
or can i add to the formula in cell AG3 which i have =COUNTIF(B3:AF3,"x")
something like then times answer by 500? to get the answer in AJ3?
Thanks in advance for any help
Why not change the formula for AJ column?
On mobile so can't check but surely =AG2*500 would do the same thing if placed in AJ3? AI column simply isn't required at all
