Help needed.
19 Sep 2007
So I've been trying to play Hell Let Loose but about every half and hour or so the game crashes to the desktop. I think my GPU (VEGA 56 sapphire pulse) is causing the crash as once it hits 72 degrees the game crashes to desktop. However, the fans are only hitting approximately 1600 rpm so not really spinning up at all in my opinion. Does anyone know how I could set the fan speed higher to try and keep the card a bit cooler?
Thanks
72 degrees is ok for gaming, you can set fan speed in many different ways but are you overclocked with cpu or gpu? If so try lowering the clocks to see if crashing stops. Updated drivers? Any BSOD errors?
