Hi everyone, I was hoping my first post for a while would be to boast about my new PC, but it turns out life's not that easy. It started well: outside the case, I could post and get into the bios. So I installed into the case and added fans and drives. But then I stopped getting any video output. I've taken everything out of the case again, and the problem remains.
Currently wired up:
PSU Corsair HX620
motherboard Gigabyte GA EX85 UD3R
i7 920
HSF Scythe Mugen 2
OCZ 3 x 2GB PC3-128000
XFX GTX 275
USB keyboard
screen
When I jump the power, the PSU fan starts fine. The eight LEDs on the board all light up. But the CPU fan starts, but cuts out almost immediately. And I get no video output. No beeps at all coming from the board.
Both the 24-pin and 8-pin power cables are in the motherboard (and have been re-fitted). The graphics card has both 6-pin cables, again both re-fitted. The 4-pin CPU fan is in the motherboard. I have tried each of the three memory modules individually, and in different slots. I have tried the graphics card in each of the PCIE x16 slots. Everything is out of the case, so there doesn't seem to be anything shorting.
What could be wrong? As I say, when I first wired everything up, I could get into the bios and the CPU temperature was reported in the low-twenties. Why would it deteriorate? Perhaps the CPU cooler has come loose somehow? (Doesn't seem like it.) Since I seem to have ruled out a memory problem, I think all I can do is try to re-fit the CPU and cooler and, if that doesn't work, RMA the motherboard?
All the components are new, and I don't have an old machine to hand that I can swap components into.
So much for the long weekend ... please help?
Edit: I have also cleared CMOS, didn't help
Currently wired up:
PSU Corsair HX620
i7 920
HSF Scythe Mugen 2
XFX GTX 275
USB keyboard
screen
