Hi All,
I am having a bit of a problem with my new PC build. I have been building it today and have just tried booting for the first time. The power lights come on, blu ray spins, and fans spin but it doesn't do anything else and I get no output to the screen.
There is a memory OK light on the motherboard that is continuiously on which according to the manual means that the memory is either not properly installed or not compatible. I have reinstalled the memory and tried pressing the button next to the memory ok light (it says in the manual that it should start flashing but it doesnt).
Any Ideas?
Motherboard - Asus P6X58D-E X58
Memory - Corsair 6GB (3x2GB) DDR3 1600MHz XMS3 Memory Kit CL9(9-9-9-24) 1.65V
TIA
Any Ideas?
TIA
thanks guys its all working now
