Hi all! Great to finally join the forum!
I know there is a huge knowledge base within this forum so I would like to pick you brains on a new PC build please:
Some background
I was very close to purchasing a semi-ok home desktop from Dell but then decided to have a shot at building my own, assuming that I will be able to get more bang for my buck. I'm an experienced software engineer with a computing degree so I'm sure I'll be comfortable building one, my only difficulty is knowing what is currently the best value/quality gear for my needs as I've been out of touch indivudal components...hence where you come in
What do I need?
A PC which can:
- Store a lot of media
- Allows me watch my media from my TV in another room (I'm assuming the only way I can do this is via Wirless Streaming to PS3 or similar via Windows Media Centre, is the quality good enough?, I want to get the best quality possible for my budget HD if possible).
- Photo & Video Editing (nothing major just amateur stuff)
- A silent or very quiet PC if possible (I assume this is down to Case, Fans)
- A slick black case, there are so many, which one is good? I don't want fancy lights just a decent quality case which is quiet and has room for expandability, a Mid Size case I presume...
I won't be gaming on the PC, nor will I be browsing much as I have an Ipad. I just want a data store really with the capability to run Windows Media Centre effectively and function as a normal PC if required.
What advice or opinions do I want from you?
- A recommended spec would be great, with details on which Motherboard, CPU, RAM, Media/Graphics Card, Storage, Case, Monitor, Anything else??
What is my budget?
I would say a max of £500 excluding Monitor. The dell PC was around £400 I think but I don't mind spending a bit more on a custom build to get me something that will last for a good few years,
Your help is most appreciated!
BG
Some background
What do I need?
A PC which can:
What is my budget?
BG
