Hi,
Just tried putting a brand new Sapphire HD7750 card in my machine and there seems to be no signal going to the monitor at all. The only possible clue is some extra clicking coming from somewhere on the motherboard before the BIOS beep. Usually there's a few clicks you only notice with the side off. With the new card this seems to go on a bit longer. Windows then starts even though I can't see it.
If I put the old card back in it works fine. The new card seems to be well seated and I've tried it in and out 3 times. The cable is the same for both cards - a dual link DVI cable. I also tried starting it connected to the TV using the HDMI port but again no signal whatsoever.
Both the new and old cards are passively cooled and have no extra power connector so I can't really see what I could be doing wrong.
According the Sapphire website the card requires a minimum 1Gb system RAM (I have 2) and 450w PSU, (I have a Corsair VX450). However I checked the AMD site and there it says the 7750 requires at least 4Gbs of RAM so I don't know if that could be the problem?? (It's an old board and won't take more than 2Gbs so that's not an option.)
I tried updating the BIOS because I could think of anything else. Now I'm out of ideas.
Any suggestions welcome. Thanks.
