HELP!!! New Graphic card.
7 Apr 2013
Hi Guys/gals
Can anyone give me an idea of a new graphic card.
Running windows 7 64bit
Have Sapphire Vapor X R9 280X
What's a good graphic card that runs either DSR or VSR
Budget £150 - £200
Thanks
Aww, the £200 R9 290 is out of stock :( otherwise it'd be a clear winner.
In that price range you're looking at a 285 or 960 if you really want that feature, but MSAA gives the same effect anyway so personally I'd stick with a 280X.
The 290 pcs+ has been on this week only for £200 quite often so keep an eye out incase it happens again. The 290 is the next logical and only step up from your current card that could be in your budget. If i was you i would hold on to what you have though as in the next 3 months i expect new cards will be hitting the market. Word has it that AMD want to release a new range from the top to the bottom so maybe something really nice will fall within your budget. In the mean time the 280x is still a pretty strong card even without VSR.
