Hi Guys
I'm requiring help on my new system build.
The system is for ADOBE cs3 Applications - NO GAMING.
Its a similar machine to what I have already, but due to this one going to my empoyee, I thought I'd build something better.
I have never over clocked and I do not know what all the numbers in the RAM mean or whats best for me, this is where I need most help. I don't need to know as much as what they are all for, but really the advantages for the apps I use.
This new machine is going to have 8gb Ram as opposed to 4 GB in my current set up.
On the list I have 2 lots of ram, 6400 and 8500+ I was wondering if the more expensive option is worth my extra money??
Currently with my BLACK DRAGON 4gb some effects take ages, with PShop CS3 I max my ram instantly all the time.
Motherboard is the same as I have now, at the time when i got it, it was quite raved about, but how true that is now I dunno.
The graphics card will go in my current machine and the 2 x 512 sapphire 2600hd's will go in my new build (have them already due to 3 x monitors (all dvi) not for power so no sli etc required)
I'm hoping to OC to 3.4ish? or is that not realistic? you tell me! please
Wanting to order ASAP today if possible.
LASTLY MY 3rd pc (old old one) is to loud! its the cpu fans -
I have a this mobo with 2 x xeon 3.06HT (2 x mPGA604 sockets)
http://www.supermicro.com/products/motherboard/Xeon/E7505/X5DA8.cfm
I measure the cpu fans at 60mm
will these do - Akasa AK-186-L2B Amber Ultra Quiet 60mm Fan - 3 pin
kind regards
SBDESIGN
kind regards
SBDESIGN
