Permabanned
- 15 Apr 2013
- Birmingham
Hi,
I have recently built a pc and attempted overclocking, now the pc only starts up to bios. I have tried re-installing windows but it just seems to crash citing the pc needs to be repaired. Most options are greyed out cannot access system recovery/repair options or cmd prompt etc.
I have tried google for answers but found nothing.
I also forgot to mention, after the pc did not boot up the first time I tried re-installing windows. When I got to the part when u select the hd/partition etc
I deleted the partitions as if did not allow me to install on those.
Having said that I installed the ssd in another pc, formatted it and i’m getting error codes like
0xc0000098
BCD file is missing
Or sometimes 0cc00000f
Winload/efi
I have reset bios via jumper and cmos.
When trying to boot from usb i get a black screen and cursor.
Also re-seated cpu....nothing seems to work.
0xc0000098
BCD file is missing
Winload/efi
