HELP! no signal on monitor
28 Apr 2011
UK
I have just got my new pc and I have put the graphics card in etc , I have attatched my monitor to it (acer monitor - VGA only) with a VGA cable - I am geting no singal on the screen anyone got any ideas? I have a HDMI to DVI converter and a HDMI cable running from my TV to the pc 's dvi slot , I am then getting no cable connected
any help is greatly appreciated
it was a prebuilt i had to put the graphics card in
i think i did it right
the PC is firing up ok
graphics card fan is spinning
The GPU was a GTX460?
it needs two 6pin power connectors in it, you done this? not one but two!!!
and i dont know how to ...
The
OCZ StealthXStream II 600W PSU, if thats whats in it?
has a 6pin and a 8pin that has a detachable 2pin making a 6pin PCI-E connectors.
they will only go into the side of the card one way around, there will be a little clip on them to keep them secure.
I dont have a camera atm , but will put some up as soon as I can, btw how can I tell that its overclocked to 4.40ghz it dont say so on CPU-Z and system requirement labs says its 3.30
Uploaded with ImageShack.us
can you run something in the background such as Furmark in another window, and then see what CPU-Z says while the cpu is working hard?
