HELP noob problems (keyboard keys)
9 Nov 2004
Pembrokeshire
HELP noob problems
somehow sticky keys (or something) has been turned on_ on my mums laptop
and it seems like the shiftkey is being held down constantly
which means one two three four five (etc) on the keyboard appear as
and i cant use punctuation at all because it comes up as <>?:@
any ideas on what i can do to turn this stuff off?
sticky keys are turned off and i@ve tried dissabling them all in accesabilities options
also opening programs in explorer need to be right click_ then opened>>> otherwise they try and open multiple programs ala shift being held down
please help< this is bloody annoying
also even clicking anywhere in a web browser make shift selections as well
Have you tried plugging a normal keyboard in? (assuming your laptop has a plug for it). If you get the problem still, its a setting in windows, if it works fine, its the keyboard on the laptop. (I'd imagine anyway)
ah
just realised i posted this in GD
also just noticed that caps lock is turned on as i type this
if i turn it off this happens NO CAPS HERE
any ideas?
just trying with an old keyboard now
!"£$%^&*()_+
still the same
must be something in the settings
any ideas anyone?
fixed it... sticky keys were turned on (although they clearly weren't)
close delete whatever... sorry for the pointless thread :o
