Hi All
Long time listener, first time caller
I have a Abit IC7-G Mobo and the chipset? fan is making a noise so I purchased a Vantec Iceberq CCB A1C cooling set but it doesnt seem to fit soooo can anyone tell me what cooling fan I can buy to fit this motherboard as the existing one seems to have clips that clip into brackets on the mobo so guess I need the same kind of system.
Also the computer has a big heat sink on the P4 chip with an Aero Master Cooler thing on top of it, is this a good cooler or should I look at changing this one also?
Lastely what software does anyone recommend for doing benchtesting and reporting temperature etc as I have no idea how to even find out what temp the computer is running at.
Sorry for all the questions and thanks in advance.
Technium
Technium
