I recently did a buget pc upgrade bought from OC and replaced my mobo, mem and cpu..
GeIL 2GB (2x1GB) PC6400C4 800MHz Ultra Low Latency DDR2
Gigabyte GA_965P_S3 (Socket 775) PCI-Express DDR2 Motherboard
Intel Core 2 Duo E2160 "LGA775 Conroe" 1.80GHz (800FSB)
anyway ive just put it together , but when I turn it on nothing whatsoever happens.. the 4 pin 12v is in so is the 24pin and everything else (I think).
Its startign to ****ing **** me off and Ive just broke one of the connectors on my arctic freezer 7 because it took ages to come out.. tho I might be able to force that through the hole.
any ideas on what I can try?
