Hi guys , I actually don't need help to OC but I need some advice.
I have an Acer Aspire 5741G since June 2011 but i haven't used it as much as i do now because i'm away from home where is my desktop PC, I never had any problems with it , but lately I needed to increase it's performance.
I mainly play wow on the lowest settings.
Ok these are the max temps on default settings.
GPU: 61 max CPU: 77 max
This laptop has a geforce GT 320m
You can see the default settings and OC settings that i've done.
I've run many tests in 3dmark06 and it's stable , i even played wow so everything is nice and smooth , i got like 5-10 more fps so it's really nice.
The temperatures are kinda the same as when it was on default settings , GPU: 67 , let's say maybe a max 70 after hours of playing. Keep in mind that i have a cooling pad so that helps a lot. I think these temps for a laptop are pretty nice.
My question is , i maxed the core clock from 500 to a max of 650mhz , the memory clock from 790 to 950mhz, will this harm my GPU or my laptop in any way? Temperature wise it's almost the same.
Should i leave these OC settings like this if everything is stable and ok temperature wise?
