Hi All,
Just having my first bash at OCing at the mo, and am currently running my 720 at 3.2GHz with 200x16.
Had prime running for about an hour so far and no problems.
CPU is sitting at 25 degrees.
Basical I've got a bit stuck, my problem is I want to try and go higher than 3.2, preferably 3.5 ish, but I think I'm most likely going to have to change voltages to do this and that is where my problem lies.
Can anyone with this board, or experience with it, tell me what I need to do in the BIOS to be able to change voltages?
Currently they are all set to [AUTO] and are completely greyed out.
The manual is proving useless so far, and I can't find anything on the net.
Any help would be great.
Thanks.
Thanks.
