Help oc'ing E7200...
12 Sep 2008
London
I know it's an older chip, but would appreciate some help pushing this further. It's been solid at 3.35Ghz on a P5Q mobo with the following settings:
FSB 350Mhz
Multi 9.5
CPU volt 1.2
CPU GTL auto
GPU PLL 1.54
FSB volt auto
NB volt 1.12
NB strap is at 266, RAM is properly set up
All other settings are on auto
Raising the FSB to 360 and notching up the CPU and NB voltages slightly gave a stable 1hr linpack test, but going up to 370 and raising the different volts by a few increments keeps failing the test after about 10 mins.
I'm not very experienced with this, so would appreciate any ideas from you oc experts out there!
