hes got a hard drive with vista on maybe this will work it is an ide drive though will that still work nowadays
also got a vista disk i think
To use it you would need an adapter.
will a AMD A6-3670K 2.70GHz (Socket FM1) APU Processor run diablo 3 ?
these are the gfx cards they Recommend for playing it
NVIDIA® GeForce® 260 or ATI Radeon™ HD 4870 or better
i cant find much in way of bench mark for the gpu in the processor is it the same as these or worse ?
thanks
lol and how much does a windows 7 install take up ?Windows7 home premium takes up around 16GB.
Rule#1 - Never skimp on the PSU.
