Went a bit over (bit of theme around here), also assuming your case is ATX?
YOUR BASKET
1 x Intel Core i5-4670K 3.40GHz (Haswell) Socket LGA1150 Processor - OEM £169.99
1 x Powercolor Radeon R9 270 TurboDUO 2048MB GDDR5 PCI-Express Graphics Card £125.99
1 x Gigabyte Z97P-D3 Intel Z97 (Socket 1150) DDR3 ATX Motherboard £69.95
1 x Crucial MX100 128GB SATA 2.5” 7mm SSD + 9.5mm Adapter (CT128MX100SSD1) £59.99
1 x TeamGroup Vulcan ORANGE 8GB (2x4GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (TLAD38G2400HC11CDC01) £55.99
1 x NZXT Hale Power 90+ 550W '80 Plus Gold' Power Supply £43.99
1 x Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) HDD £43.99
1 x Raijintek Themis Direct Contact CPU Cooler £19.99
Total : £603.98 (includes shipping : £11.75).
Yeh I have a Zalman Z11 plus, Would the £15 saving on a Gigabyte GTX 750 Ti 2GB be a sacrafice on preformance? Also would a corsair 430w modular psu be okay for this spec?
750Ti would be a bit of a downgrade in performance, if you wanted to go slightly cheaper I'd look at an R7 265 instead. http://anandtech.com/bench/product/1127?vs=1130
A CX430 would probably be OK running it, but I wouldn't want to be overclocking anything too much.
The NZXT I included in my spec is probably the best price/performance atm, but it isn't modular. The Z11 Plus is a fairly large case though so you could hide any spare cables behind the motherboard tray or tie them up in the lower HDD cages.Okay, thanks, could you recommend any good low price modular psu's at around 500w?
