Help on building PC?
What is your budget?
Edit:
I would do something like this:
YOUR BASKET
1 x Intel Core i5-4670 3.40GHz (Haswell) Socket LGA1150 Processor - Retail £179.99
1 x HIS HD 7850 IceQ 2048MB GDDR5 PCI-Express Graphics Card (H785Q2G2M) £169.99
1 x Gigabyte Z87-D3HP Intel Z87 (Socket 1150) DDR3 ATX Motherboard £109.99
1 x BitFenix Ronin Tower Case - Black £69.95
1 x Patriot Viper "Black Mamba" Generation 3 8GB (2x4GB) DDR3 PC3-17000C11 2133MHz Dual CHannel Kit (PV38G213C1K) £65.99
1 x XFX Pro 650W Core Edition '80 Plus Bronze' Power Supply £64.99
1 x Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) HDD £49.99
1 x OcUK 20x DVD±RW SATA ReWriter (Black) - OEM £16.99
Total : £740.48 (includes shipping : £10.50).
PSU - XFX is built by Seasonic, the best on the market
Gigabyte board is the best budget board
Case is personal preference
Faster RAM gives you a more responsive and efficient system, 2133+ would be a good solid choice
G/Card, 560Ti is not great, the 7850 is a better card and you get £150 of free games.
I would also recommend a decent cooler like the Cooler Master 612S, Thermalright True Spirit 140, Alpenföhn Matterhorn/Brocken)
What do you mean? Are the parts I selected bad? I know they're slighty over £400 but i still afford that.
You said your budget was £400, the components in your first post will cost more than that.
That exceeds my budget of around £400
For a decent first build, I would be looking at spending about £600, at least.
If we knew what your maximum budget was, we could then spec you a decent build.
What will be the main uses for this system?
This would be my spec for £450. Which would be ideal for general browsing and some light gaming.
YOUR BASKET
1 x EVGA GeForce GTX 650Ti 1024MB GDDR5 PCI-Express Graphics Card (01G-P4-3652-K1) £99.95
1 x Intel Core i3-3220 3.30GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £92.99
1 x ASRock B75M Intel B75 (Socket 1155) DDR3 Micro ATX Motherboard £52.99
1 x Crucial Ballistix Sport 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (BLS2CP4G3D1609DS1S00CEU) £49.99
1 x XFX Pro 450W Core Edition '80 Plus Bronze' Power Supply £39.95
1 x Xigmatek Asgard Pro Gaming Case - Black £32.99
Total : £449.94 (includes shipping : £11.75).
You can use Win 8 Enterprise free, for 3 months until you decide on 7 or 8.
http://msdn.microsoft.com/en-gb/evalcenter/jj554510.aspx
Or you could get this mobo and add an i5 at a later date when you feel you need a bit more of a performance increase.
http://www.overclockers.co.uk/showproduct.php?prodid=MB-364-GI&groupid=701&catid=5&subcat=1990
