Hi guys,
I`ve finally managed to get my E6600 stable at 3.240 ghz @1.40vcore with a load after 8 hours of dual prime 95 (small ffts) @ 53 deg. I wanna let the TIM on my tuniq cure so wanna get the ram up to speed now. My ocz gold edition 667 is running (according to cpuz) at :
360mhz
FSB - 1:1 (set at sync in bios)
CAS latency @ 5
RAS CAS delay @ 6
RAS precharge @ 6
Cycle time @17
bank cycle time @ 22
command rate @ 2T
voltage is 2.1 in bios
I`m aware that the fsb is overclocked but would i be better setting it at a 667 divider in the bios then trying to tighten up the above settings? (ANY ADVICE ON WHICH TO CHANGE WOULD BE AWESOME AS THE MEMORY CONFUSES ME!!!)
Thanks for the help!
Cheers,
Smegle
360mhz
CAS latency @ 5
RAS CAS delay @ 6
RAS precharge @ 6
Cycle time @17
command rate @ 2T
Cheers,
Smegle
