(Apologies, posted this initially in the wrong section)
Hi guys,
I`ve finally managed to get my E6600 stable at 3.240 ghz @1.40vcore with a load after 8 hours of dual prime 95 (small ffts) @ 53 deg. I wanna let the TIM on my tuniq cure so wanna get the ram up to speed now. My ocz gold edition 667 is running (according to cpuz) at :
360mhz
FSB - 1:1 (set at sync in bios)
CAS latency @ 5
RAS CAS delay @ 6
RAS precharge @ 6
Cycle time @17
bank cycle time @ 22
command rate @ 2T
voltage is 2.1 in bios
I`m aware that the fsb is overclocked but would i be better setting it at a 667 divider in the bios then trying to tighten up the above settings? (ANY ADVICE ON WHICH TO CHANGE WOULD BE AWESOME AS THE MEMORY CONFUSES ME!!!)
I`ve found this review on the ram, shall i try the timing they have tried here and see if it stays stable through a prime 95 blend run (do i still have to run two prime 95`s as i`m just going for ram now)
(timings used are 5-5-5-15)
Thanks for the help!
Cheers,
Smegle
Hi guys,
360mhz
CAS latency @ 5
RAS CAS delay @ 6
RAS precharge @ 6
Cycle time @17
command rate @ 2T
Cheers,
Smegle
