- 11 May 2012
- Redcar
Which of these two programs shows the right CPU temperatures. At ideal they are about the same but when running prime95 there is 10c to 15c difference.
CPUID is accurate core temp. Doesn't really matter if Fan Xpert shows 45c when core is really 60c.That would make Fan Xpert useless as the fans controled by it would not ramp up as they are needed inline with the true temperature.
