Help on custom pc
25 Sep 2005
Hi guys,
Iam building a new pc for gerneral gaming and iam hoping to be able to run most games at mid-high setting. I want to make sure if these components will run together fine.
Tips on whether if i can get a better component would be nice.
Should i go dual core for the cpu? and is overclocking an option if i decide to try it out?
Budget: 800
Asus A8N-E nForce4 Ultra (Socket 939) PCI-Express Motherboard (MB-088-AS) £64.57
AMD Athlon 64 3700+ San Diego 90nm (Socket 939) - OEM (CP-150-AM) £123.32
Thermaltake VB1000BWS Soprano SuperMidi Tower - Black (CA-015-TT) £50.47
GeIL 2GB (2x1GB) PC3200 Value Dual Channel Kit CAS3 (GE2GB3200BDC) (MY-046-GL) £129.19
Zalman CNPS7000B-CU Ultra-Quiet CPU Cooler - Retail (HS-007-ZA) £22.27
Seagate Barracuda 7200.9 200GB ST3200827AS SATA-II 8MB Cache - OEM (HD-056-SE) £56.34
Tagan TG480-U22 480W ATX2.01 2Force SLi Compliant Silent PSU (CA-004-TG) £64.57
Total : £504.85
295.15 for a GPU
Asus GeForce 7900 GT/2DHT TOP 256MB GDDR3 TV-Out/Dual DVI (PCI-Express) - Retail (GX-099-AS) £223.19 Maybe a X1900 instead?
Ok i changed the ram and the psu. Anything else i should change?
Nope they wont work, you have specced DDR2 ram with s939 which uses DDR memory. I'd get a tagan 480w instead of the thermaltake as well
