- 11 Mar 2016
I need some advice on how i will watercool my GPU CPU
Currently if you take a look at my thread in the sig you will see the build.
The current flow is water goes like this
PUMP>CPU>MOBO>240MM RAD> 360MM RAD > reservoir > back to PUMP
My CPU temps float around 25-29c on the 6700k @ solid 4.5Ghz.
I'm about to add 2 x GTX 1080's
Would it be sensible to have the flow as
PUMP>GPU1 > GPU 2 > CPU>MOBO>240MM RAD> 360MM RAD > reservoir > back to PUMP
or
PUMP>CPU>GPU1 > GPU2 >MOBO>240MM RAD> 360MM RAD > reservoir > back to PUMP
I guess in essence best to have it hit the GPU's first then CPU second or CPU first then GPU's second?
or
